Programmable Devices
20704 Discussions
Arria 10 GX development kit DDR4
TPH_zenith
If I do not select ECC for the memory controller can I use the 8 ECC bits as data bits. Therefore my data bus width will be 72 bits instead of 64 bits plus ECC?
AdzimZM_Intel
We do not receive any response from you to the previous reply and answer that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
sstrell
I'm pretty sure the DDR4 that comes with that kit is only 64 bits, so I'm not sure what you could do with a 72 bit bus.
But sure, you can set that up if you want.
AdzimZM_Intel
Do you any further question in this topic?
AdzimZM_Intel
