21607 Discussions
Arria 10 Linux Kernel
JoshuaWillson
Hi All,
I am trying to boot (linux-socfpga) linux kernel on the Arria 10 SoC.
Does any one have any knowledge on which tools chains need to be used for which versions of kernel
When I build ACDS20.1 (https://github.com/altera-opensource/linux-socfpga/tree/ACDS20.1_REL_GSRD_PR) with tool chain gcc-linaro-7.5.0-2019.12 (arm-linux-gnueabihf) I can get my build to boot.
When I build ACDS21.1 (https://github.com/altera-opensource/linux-socfpga/tree/ACDS21.1_REL_GSRD_PR) with tool chain gcc-linaro-7.5.0-2019.12 (arm-linux-gnueabihf) I can NOT get my build to boot.
Do I need to change the following compatible line in the DTS?
model = "Altera SOCFPGA Arria 10";
compatible = "altr,socfpga-arria10", "altr,socfpga";
Does anyone have any info on this?
Thanks!
-JW
mabdrahi
Hi Joshua,
I will check your request on compatible line in the DTS.
I will come back to you soon.
Thank you,
Aliff
mabdrahi
HI Joshua,
May i have the following item:-
1 What board are your use (Intel dev of Arrow dev, custom board)
2 What design are using (GSRD, ref design)
3 Any hardware modification
4 Software modification(uboot, linux kernel)
5 do you have error log ?
Thank you,
Aliff
JoshuaWillson
     Answer: Terasic HAN Pilot Platfrom Arria 10 SoC
    Answer: GHRD that Terasic points too in following link https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=216&No=1133&PartNo=4#contents REVF
     Answer: Adding in soft IP TSE design, w/ MSGDMA, HPS i2C, and pio for connecting a design w/ SFP modules
     Answer:
        uboot: v2023.10
        linux kernel: Linux version 6.1.38
    Answer:
        No error log: Could not even get the kernel to boot. But this is where it stops:
            Starting kernel ...
           Deasserting all peripheral resets
Please note:
For any one with the same problem it came down to the DTB. Im not sure what part exactly from the DTB the kernel did not like but I had different versions of a DTB from example designs and the one that worked was the DTS from a10s_tse_example_design from rocketboards. I was using the DTS from the compiled DTB from terasic that came with the development board and that one was causing issues.
MY assumption is there was some peripheral that the kernel could not talk too (i2C, spi, etc) that was hanging the kernel.
mabdrahi
Hi Joshua,
Can you share all your booting log?, it might have information's there.
Thank you,
Aliff
mabdrahi
Hi Josua,
Currently I tried the https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10#Cyclone_V_SoC_45_Boot_from_QSPI
but what i encounter is the error during linux compilation.
After I manage to compile successfully I encounter the board is no boot.
I still working on it, give me some time
Thank you,
Aliff
mabdrahi
mabdrahi
Hi Joshua,
can i have update from the work around?
Thank you,
Aliff
JoshuaWillson
I had to go through my DTS and make sure there was no peripherals that were instantiated that the Kernel could not connect/talk too. When it attempted to "Dessert All Peripherals" it would just hang.
mabdrahi
Hi Joshua,
Apologize for being lates as im sick leave.
Can you share your DTS here?.
Hang issue also can cause from hardware side.
Thank you,
Aliff
mabdrahi
Hi Joshua,
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you,
Aliff
