We are using an Arria 10GX but not using the transceivers. According to the documentation we still need to power a few VCCR_GXB pins for proper operation of the FPGA. Since we are not using the transceivers can we safely just power these pins with 0.9V, or do we need to add a 0.95V supply for these pins? Thanks.
Hi there
We need to make sure those pins listed in the banks below is powered on to its operation level:
The allowable range mentioned in datasheet is 0.92 - 0.98V.
Topic Options
