Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Arria 10 reclk frequency limitations of fPLL
When instantiating an fPLL (in Qsys) with a reference clock frequency of 50 MHz the fitter reports the following error:
Error (15653): The Fitter cannot find a legal configuration for the following atoms. Update any outdated transceiver PHY IP cores, correct any illegal pin assignments, and then recompile your design. Error (15744): In atom 'FS2_Arria:u0|altera_xcvr_fpll_a10:xcvr_fpll_a10_0|fpll_inst' Error (15744): The settings must match one or more of these conditions: Error (15744): ( sup_mode == ENGINEERING_MODE ) OR ( prot_mode == UNUSED ) OR ( refclk inside {0:49000000,210000000:68719476735} ) OR {((set_fpll_input_freq_range*36'h00002625a0)>((refclk-36'h0002faf080)-36'h00001312d0))} Error (15744): But the following assignments violate the above conditions: Error (15744): pll_sup_mode = USER_MODE Error (15744): prot_mode = BASIC_TX Error (15744): reference_clock_frequency_scratch = 50000000
The target device is an Arria 10 and I use the fPLL in Core mode, i.e. I don't use it for a transceiver but for synthesizing some user clock.
The error message suggests that I have to change on of the parameters sup_mode, prot_mode or refclk. However
  • sup_mode ist not meant to be changed by the user (it is also not accessible from Qsys)
  • UNUSED is not a valid value for parameter prot_mode
Which leaves me with changing the refclk frequency. Indeed, if I change to 40 MHz, the fitter does not report any errors.
My question is: is this a real limitation or is there another way avoiding this error? Where does this limitation come from and where is it documented?
Thanks in advance!
What's the output clock(s) you are trying to generate from the 50 MHz?
The desired output frequency is 24 MHz. Qsys seems to be ok with that ;)
This is a known bug (https://www.altera.com/support/support-resources/knowledge-base/solutions/fb371226.html): the reference frequency must be outside [49 MHz, 51.5 MHz].
Can I set the reference clock frequency parameter to 48 MHz when the actual frequency is 50 MHz?
