21345 Discussions
Arria V DDR3 UniPHY Report DDR
Hi,all,I use QII14.0.2 and my chip is 5AGXMA5D4F27C5.I instantiated two DDR3 SDRAM Controller with UniPHY in Qsys,and the memory clock frequency is 500Mhz.I finish compilation but report DDR timming have some issue(the Address Command Path not passed).How can I solution it?Should I modify the parameter at Board Settings tab?How to do?
thanks for your helps.
http://www.alteraforum.com/forum/attachment.php?attachmentid=9809&stc=1
