21345 Discussions
Arria V FA support request for Honeywell 5AGXFB5K4F40I3G- 2pcs
RobertOlson
BEI Part #: HWL52000859-50
Mfg. Part #: 5AGXFB5K4F40I3G
Parts purchased from Arrow Electronics
Original PO #: WPM288854
Quantity to return: 2
Date code: 2131
Reason for return: Physical damage found prior to use- chip out & long defect line with no trace inside  -  see attached pictures
Zawani_M_Intel
Hi RobertOlson,
Good day!
Thank you for using Intel FPGA Community Forum.
Can I know the status of this unit either it is fresh raw unit or it has been undergone several test before use?
Thanks!
Wani
RobertOlson
Hi Wani,
                These parts are fresh, unused units. They have not gone through any processing or testing.
                The physical damage was found prior to use- chip out & long defect line with no trace inside
Thank you,
-Rob Olson
507-535-4083
Zawani_M_Intel
Hi Rob Olson,
We will continue support your case through private email as we need some confidential detail.
Thank you!
Wani
