I'm sorry, it's solved:
under ..\More Timing Settings\Ignore Clock Settings should be set to OFF !!- Mark as New
The original post was using classic timing analyser that is no longer available.
You need to write an SDC file that defines all of the timings for the design- Mark as New
Sorry i don't know how to write an SDC. is there any other way we could solve this... ? or could you please give me a small SDC eg. ?
You need to write an SDC file to constrain your design. At a minimum it defines the clock, but also things like false paths, multicycle paths, IO delays etc.. Read this tutorial here:
https://www.altera.com/en_us/pdfs/literature/ug/ug_tq_tutorial.pdf
Topic Options
