Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Autoreconf : linking to static library with Libtool
I have a library (curl) that is compiled in static which gives libcurl.a and I have another library (microxml) which is compiled in static which also gives libmicroxml.a .I have tried to make a link between these 2 library and autoreconf. First ,I try to add these lines in this way in Makefile.am
Easycwmpddir = / home / amine / ecos Easycwmpd_LTLIBRARIES = libcurl.a
libmicroxml.a
And add this line in configure.ac
LT_INIT (LIBTOOL)
when I made the following command: autoreconf -i It gives the following error:
Bin / Makefile.am: 34: error: 'libcurl.a' is not a standard libtool
library name Bin / Makefile.am: 34: did you mean 'libcurl.la'? Bin /
Makefile.am: 34: error: 'libmicroxml.a' is not a standard libtool
library name Bin / Makefile.am: 34: did you mean 'libmicroxml.la'?
Even if i changed libcurl.a by libcurl.la The autoreconf -i command works and so on for this command
./configure --disable-shared
But when I typed the command: Make
He gave me the following error:
Make [1]: *** No rule to make the target "libcurl.c", needed for
"libcurl.lo". Stop.
So I tried to make another solution in which I addthese lines in Makefile.am
Easycwmpd_LDADD = / home / amine / ecos / libcurl.a
/home/amine/ecos/libmicroxml.a
then i add this line in configure.ac
LT_INIT (LIBTOOL)
when I made the following command: autoreconf -i works and so on for this command
> ../src/easycwmpd-backup.o: In function `backup_add_event ': Backup.c
> .text + 0x11d3): undefined reference to `asprintf ' Backup.c
> .text + 0x1280): undefined reference to `asprintf '
> ../src/easycwmpd-config.o: In function `config_init_local ': Config.c
> .text + 0x138): undefined reference to `asprintf '
> ../src/easycwmpd-easycwmp.o: In function `main ': Easycwmp.c .text
> + 0x237): undefined reference to `fork ' Easycwmp.c .text + 0x2ed): undefined reference to `asprintf ' Easycwmp.c .text + 0x34a):
> undefined reference to `closelog ' ../src/easycwmpd-http.o: In
> function `http_get_response ': Http.c text + 0x4b7): undefined
> reference to `asprintf ' ../src/easycwmpd-xml.o: In function
> `xml_mxml_find_node_by_env_type ': Xml.c text + 0x540): undefined
> `xml_get_hold_request ': Xml.c text + 0x786): undefined reference
> to `asprintf ' Xml.c text + 0x81e): undefined reference to
> `asprintf ' ../src/easycwmpd-xml.o: In function `xml_handle_message ':
> Xml.c .text + 0x929): undefined reference to `asprintf '
> ../src/easycwmpd-xml.o:xml.c.text+0xe26): more undefined references
> to `asprintf 'follow Collect2: ld returned 1 exit status
can you guys, explain to me if i was wrong doing this , or can you give me any guidelines or any help i will appreciate that
