20704 Discussions
Availability of MAX 10 devices in 144-EQFP packages?
Currently, www.buyaltera.com lists only 19 available parts for a single MAX 10 device, 10M08SCE144C8G, that uses a 144-EQFP package. No other vendor according to www.octopart.com or www.findchips.com appears to have any more significant stock. I am interested in 10M25SCE144C8G and 10M50SCE144C8G parts. Is Altera committed in the long run to these particular packages and if so, when will they be readily available? I don't want to start on a new design without confidence in the supply.
Steve
This is a question you will need to direct to your Altera FAE as only Altera can answer what its long term packaging strategy is for this device.
Did you try www.digikey.com ?
