Hey everyone!
We're trying to use an on chip memory fifo in SOPC that converts Avalon-MM to Avalon-ST. The on-chip fifo memory sends the data through an Avalon-ST source and a custom component that has Avalon-ST sink receiving it. A custom component is used to export the avalon-st sink signals to the outputs external of the SOPC. When sending data to the fifo with the Avalon-MM write nios commAND, the fifo (ST-Sink) outputs only two bytes from the message, without a valid coming along with the eop. What could the problem be? Could it be the export of the Avalon-ST sink outside the SOPC? Thanks in advance, Omri.Link Copied
