Programmable Devices
20704 Discussions
BSP setting for "UDP Offload Example"
I am modifying the "UDP Offload example" available on Altera wiki for my board(DE2-115) but I got following error while building the project using
./create-this-app command in command mode:
"undefined reference to `stooges'
could any body please help?
Hii !
Did u solve the problem ?
i am getting the same problem !
thanks !
Have You tried "UDP Offload example" successfully on DE2-115, Even I am trying Am having problems in modyfying the project Can you share your project arhieve.
Arun
yes i did
what kind of problems do u have ?
--- Quote Start ---
yes i did
--- Quote End ---
I am using Quartus 14.0 version, so qsys file didn't get upgraded automatically So removed old tse_mac component from qsys system and added new one(14.0).
Now I am having problems and I cant generate the system. Can you share your qsys system screenshots?
Arun
have fun
Jalayan
--- Quote Start ---
have fun
Jalayan
--- Quote End ---
Thanks for sendig the qsys file, Now am able to generate qsys design successfully, But compilation of my top level design is failing.
Can you please send the quartus archieve of the full project so that I will cross verify where am making mistakes.
Thanks and Regards
Arun
It took me more than a week to get this working.
here you go ..
Jalayan
--- Quote Start ---
here you go ..
Jalayan
--- Quote End ---
Thank you very much for sending the files.
I am having problems in compiling the code..
I am getting two errors
undefined reference to install_menu()
undefined reference to stooges()
But I have defined IN_MENUS to 1 in demo.c file
But if you see in the menus.c file code portion containing IN_MENUS is greyed, and if i right click on IN_MENUS and click find declaration error "couldn't find IN_MENUS in the index" will come.
Do i need to include something or do i need to change some project settings ?
there is a couple of changes in the iniche Stack, that's why you get these two populer errors.
You need to disable the file generation for the following files (in the BSP Editor):
tk_crnos.h
tk_crnos.c
targnios.c
osportco.c
nrmenus.c
ipport.h
app_ping.h
app_ping.c
copy the original files that i gave you in your project directory.
Jalayan
popular**
I also enabled
* net_stat (software packages)
Jalayan, seems you've become very familiar with the UDP Offload Example. Do you know who the author might be? I thought I saw it here in the forums somewhere but can't seem to locate it.
