21415 Discussions
Bi-direction signal issues
Hi Guys,
I met an issue for Bi-direction signals. When the state is for output from FPGA, the data is not correct... Please help me.
So I have a top module and connect the inouts to a submodule, and the value assignment is in the submodule. Will this be an issue?
Here is part of the code:
entity top is
port(
clk : in std_logic;
nRst : in std_logic;
emif_cs_n : in std_logic;
emif_R_nW : in std_logic;
emif_addr : inout std_logic_vector(9 downto 0);
emif_data : inout std_logic_vector(7 downto 0)
end top;
architecture behavior of top is
component sub is
port(
clk : in std_logic;
end top;
sub_u: sub
port map(
nRst => nRst ,
clk_100M => clk_100M ,
emif_cs_n => emif_cs_n ,
emif_R_nW => emif_R_nW ,
emif_addr => emif_addr ,
emif_data => emif_data ,
end behavior;
entity sub is
port(
clk_100M : in std_logic;
--emif
end sub;
emif_data <= rdata_reg when (rd_period = '1') else (others => 'Z');
emif_addr <= raddr_reg when (emif_cs_n = '0' and emif_R_nW = '1') else (others => 'Z');
here is from signaltap
https://alteraforum.com/forum/attachment.php?attachmentid=15595&stc=1
So what causes the bi-direction signals not following the register value?
(Virus scan in progress ...)
You dont show what rd_period or emif_cs_n and emif_R_nW. If these are setting the bus to 'Z', then you will be reading the values coming from off chip.
--- Quote Start ---
--- Quote End ---
Hi, they were always in "emif_cs_n = '0' and emif_R_nW = '1'" contition... That's why I think it's weird..
OK the issue is solved. The problem is: the other side is also sending data to FPGA during the period, so both sides are sending data, there is conflict~~
