21601 Discussions
Build single FPGA SOF file to work with multiple Aria10 devices
bikirangoswami
I am using 2 different Aria10 devices, both very similar. In fact, identical pinout.
Device1:  10AX027E4F29E3SG  and Device2: 10AX032E4F29I3LG.
Is it possible to build a single SOF file to be compatible with both devices ? Or do I need to build specifically for each device ?
Thanks!
roeekalinsky
Valued Contributor I
You need to build specifically for each device.  They differ in their internal resources.
