21611 Discussions
Burst mode of DDR SDRAM
Dear all,
I am not very understanding burst mode, we all know DDR SDRAM has burst length of 2 or 4 or 8. Does it mean the transfer data length should be times of 2 or 4 or 8?
What is the units of burst length?
For example, if I have 16 bytes, transfer in a burst length of 2, do I need to issue 8 command read/writes?
What if my data size is odd? does it mean either I need to repack the data to times of burst length? or tranfer most of the data in burst mode, the remaning data in non-burst mode?
Thank you very much!
--- Quote Start ---
Dear all,
--- Quote End ---
For SDR - yes. And you can use full page mode.
--- Quote Start ---
--- Quote End ---
Word. If you use 8 bit SDRAM you burst 8 mean 8 bytes. If you use 4 bit wide burst 8 give you 4 byte.
--- Quote Start ---
--- Quote End ---
Yes. And you may no need change page.
--- Quote Start ---
--- Quote End ---
You can use mask pin in DRAM. It's 8 bit wide pin. En example if you need to write 8 bit data to 32 bit DRAM. You need to mask 3 byes and unmask one byte.
hey i dont think any of the ddr's support the full page mode.burst lengths of 2 / 4 are the only ones supported by the ddr.this increases to 8 in the ddr3. i think atrem_bond may have answered regarding the sdram memory by mistake.
the burst length will determing the number of consecutive read/write operations the ddr will perform to get the corresponding amount of data read/written. for e.g. with a burst length of 4 and a read operation with a data width on the dram size of 8, the dram will start performing a read operation from the starting address given to the next 4 '8'bit locations and will output 8-8-8-8 bits of data in all to the user. the column address will increment internally as long as the row doesnt reach the end. also,since it is ddr, the 4 read transactions will take a total of 2 clock cycles on the memory side. and you dont have to give 4 read transactions for the same. only 1 read transaction with a burst length of 4 has to be selected for the above operation and so forth.
take care
kk
