Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Burst operation in avalon bfm.
I am doing burst write operation using avalon bfm.
For burst operaion shall i need to pass the data and address for all burst or bfm will automatically generate the data and address.
In below task i am only passing base address and the randomized data. But in simulation result I am getting only one data.
Please anyone give me some idea about this.
task automatic mm_send_cfg_write;
input [34:0] addr;
input int data[int];
`MM_BFM.set_command_address(addr << 2);
`MM_BFM.set_command_burst_count(8);
`MM_BFM.set_command_burst_size(8);
`MM_BFM.set_command_init_latency(0);
`MM_BFM.set_command_request(REQ_WRITE);
for(i=0;i<8;i++)
begin
`MM_BFM.set_command_data((data),i);\
`mm_bfm.set_command_byte_enable(4'hf,i);
end
`mm_bfm.set_command_idle(0, 0);
`mm_bfm.set_command_timeout(0);
`mm_bfm.push_command();
while (`mm_bfm.get_response_queue_size() != 1)
@(posedge `mm_bfm.clk);
`mm_bfm.pop_response();
$display("%0t mm traffic generator id configuration write: addr: 0x%h data 0x%h",$time, addr, data);
$display("mm traffic generator id configuration write: addr: 0x%h data: 0x%h", addr, data);
endtask
task data_init(output [31:0] data [int]);
for(i=0; i<8; i++)
data = {$random(), $random()};
endtask
initial
begin
data_init();
mm_send_cfg_write('d0,wdata);
end
venkat
