21462 Discussions
Bypass capacitors layout for CycloneV 5CGXFC5F6M11
AGofs
Hi everybody,
I've placed CycloneV 5CGXFC5F6M11 (MBGA, 301pin, 11mmx11mm) on the Component Side of the PCB.
I want to place the bypass capacitors on the Print Side .
1). Do you have an example with MBGA-301 layout?
2). Which capacitor case (0201,0402 etc.) do you recommend for Bypass capacitors?
3).What is recommended Bypass capacitance for MBGA-301?
4).What is a recommended capacitance for VCC_AUX,VCC,VVPD etc?
JonWay_C_Intel
Hi @AGofs​
1) No example
2) No recommendation, you can decide.
3) & 4) Check with the Power Distribution Network Tool for recommended capacitance. https://www.intel.com/content/dam/altera-www/global/en_US/others/technology/signal/power-distribution-network/pdn-tool-28nm.zip
Read PDN AN: https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/an/an750.pdf
