Programmable Devices
21420 Discussions
CLKMUX simulation
ichud
I'm using clkmux in my design. However, when  I try to run simulation my project the Questa shows me an error
vsim work.clkmux
# vsim work.clkmux
# Start time: 12:14:30 on Jul 26,2024
# ** Note: (vsim-3812) Design is being optimized...
# ** Error: XXXXXXXXXXXXX/clkmux/synthesis/submodules/clkmux_altclkctrl_0.v(70): Module 'fiftyfivenm_clkctrl' is not defined.
# For instance 'clkctrl1' at path 'clkmux.altclkctrl_0.clkmux_altclkctrl_0_sub_component'
# Optimization failed
# ** Note: (vsim-12126) Error and warning message counts have been restored: Errors=4, Warnings=1.
Where can I find this fiftyfivenm_clkctrl source code?
Definitely, I can use a simple mux for simulation purposes only and use clkmux IP for the synthesis but would like to have the same code for both cases.
Kenny_Tan
Sorry for the late reply on this, do you still need any help for this post?
ichud
Well, it seems working in the real design in the chip. However, having a reliable simulation source would be great anyway,
