Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
CPLD Hard Reset
Hi all,
I am using a Max 10: 10M02SCM153C8G . I am facing a problem with reprogramming it. After programming the CPLD, now the JTAG is not able to identify the CPLD at all . This is the first time I am encountering such a problem. I want to know if there is a way of doing a hard reset on the CPLD to bring it back to its original state. Kindly let me know the procedure on how to do a Hard Reset on the CPLD.
Sid
Handbook says that in some situations, e.g. after issuing reserved JTAG commands, a power cycle is required. Or are you disabling JTAG in user mode?
Hey, thanks for the reply, but i am not using any reserved JTAG commands, I am using a byte blaster to program the CPLD.
But now I am getting the below error message:
Error: Can't access JTAG chain
Error: No device detected
Since the byte blaster is not able to see the CPLD at all I am not able to reprogram it and I need to hard reset the CPLD to bring it back to the original state.
