CRC jam file
Using the jam file below
NOTE MAX_FREQ "10000000";
ACTION CONFIG_IO = EXECUTE;
PROCEDURE EXECUTE;
BOOLEAN X = 0;
DRSTOP IDLE;
IRSTOP IDLE;
STATE IDLE;
IRSCAN 10, $015;
DRSCAN 32, $FFFFFFFF;
STATE IDLE;
EXIT 0;
ENDPROC;
I simulated the above jam file using quartus_jli.exe (command line jam player), it gave me output as
Expected CRC not found, actual CRC value = AB60
Export: key = "JAM_STATEMENT_BUFFER_SIZE", value = 1051
NOTE "MAX_FREQ" = "10000000"
Exit code = 0.. Success
Using the above JAM file, I modified the line# 9 to an arbitrary number ("1FFFFFFF1"), to change the CRC checksum value and i got the output as
Expected CRC not found, actual CRC value = 493F
In this simulation, I am not able to understand the "Expected CRC not found" instruction.
Can anyone please help me about this problem and suggest me the solution.
Thankyou in advance
