21615 Discussions
CRC location in OnChip Flash
Utsavi
I am beginner for Nios II Programming.
Please solve my below queries.
1. In .pof file where can I found CRC of Image.
2. If I am flashing .pof file, in which location of OnChip Memory, this CRC Stored?
3. Is there any way to do burst read/write operation instead of Dword by Dword in On Chip Flash?
Utsavi B.
EricMunYew_C_Intel
Hi, Utsavi
Are you referring to the on-chip flash of MAX10 ?
Eric
EricMunYew_C_Intel
Hi, Utsavi
For your question 3, you may refer to below:
You can do burst read or a single 32bit read on the on-chip flash UFM of MAX10.
You may refer to page 16 of below document.
But you can only do a single 32bit write on UFM of MAX10.
You may refer to page 12 of below document.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_ufm.pdf
Eric
EricMunYew_C_Intel
Hi, Utsavi
You can find answers below:
You cannot find CRC from the .pof
Normally, CRC is stored in the 32bit storage register.
Eric
EricMunYew_C_Intel
Hi, Utsavi
Can I close this ?
Eric
Utsavi
Hi Eric,
Thanks for Reply.
Can you tell me the exact Register Name/Address.Or if there is any doc in which this CRC Register is mentioned.
Utsavi B.
EricMunYew_C_Intel
EricMunYew_C_Intel
Hi, Utsavi
Can I close this if you have no more inquiry ?
Eric
