21071 Discussions
Can EPM3032 GLCK2/ GCLRn/ OE1/ GCLK1 be used as INPUT pins like regular I/O pins?
MINWOO-SEO
@EPM3032ATC44-10N
@CPLD
@Quartus
EPM3032ATC44-10N CPLD product
Pin 37: GLCK1
Pin 38: OE1
Pin 39: GCLRn
Pin 40: GCLK2
Can the pin be used like a regular I/O port?
Can it only be used on the INPUT pin?
Pins 37 to 40 above are required. but
Since it seems to be designated as a pin that plays several important roles, such as the global OE1 pin, I would like to inquire whether it can be used as a basic I/O port or INPUT pin.
_AK6DN_
Valued Contributor II
Yes, those pins all drive into the internal PIA matrix and thus can be used as an input into any logic equation.
Inputs only however, there is no output capability on those pins.
_AK6DN_
AqidAyman_Intel
Yes, correct. For more information, you can refer to the device block diagram as illustrated in the page 5 from below link:
https://www.intel.com/content/www/us/en/content-details/654926/data-sheet-max-3000a-programmable-logic-device-family.html?wapkw=max%203000a
AqidAyman_Intel
I hope the previous response was sufficient to help you proceed. As we do not receive any response from you on the previous reply have been provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you by replying to this thread.
Otherwise, it was really appreciated if you can take the evaluation survey and it will be really helpful if you can rate for the excellent support you experienced. If you feel your dissatisfied with the support experience, please let me know the cause by replying to this thread so that I can improve your future support experience.
