Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Can SGDMA connect VIP megacore function directly,such as clocked_video_input?
In VIP user guide,it says that the VIP megacore function transfers video stream using Avalon-ST video protocal.
There is Packet type identifier in the stream which is not needed in the Video Processing.
If I connect like below:
Clocked_Video_Input----(Avalon-ST)------>SGDMA------(Avalon-MM)----> PCIe
Then the PCIe will get video data WITHOUT Packet type identifier?
Or the Identifier STILL is in the video stream?
Thanks for your answer.
Highlighted
Re: Can SGDMA connect VIP megacore function directly,such as clocked_video_input?
In Avalon-ST video standard,there is control packet sent before video packet.
If I use SGDMA to connect to Avalon-ST video source,such as Clocked Video Input or Color Sequence Plane,Then can SGDMA just output video packet,without Control Packet?
