Programmable Devices
20703 Discussions
Can a Cyclone IV Low Voltage (1V core) be dropped in to an 1.2V socket
PGigl
Partner
We are looking for EP4CE15F23I8N devices, but cannot find any.  Would a EP4CE15F23I8LN ​device work in this socket.
YuanLi_S_Intel
Hi Paul,
It would better if you could supply 1.0V instead of 1.2V as the core voltage is 1.0V.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-iv/cyiv-53001.pdf (Page 4)
YL
PGigl
Partner
That really does not answer the question. I believe the L option is only a speed binning of the devices, and the L devices are faster devices that can meet the timing specs even when operating at lower voltages. This is an issue of parts availability. The existing design uses non L parts, but L parts are available. ​
YuanLi_S_Intel
Hi Paul,
Apologize for the misunderstanding, for your information, L parts means low voltage device and the device is designed to work with core voltage of 1.0V. Thus, it is recommended to have 1.0v supplied to it.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-iv/cyiv-51001.pdf (Page 12)
YL
JDWYE1
We have accidentally done this (wired 1.2 V to VCCINT for Cyclone IV low voltage device) and this design has been running for 10 years.
I was looking on forums to see what this does to timing analysis - I believe it would help (fortunately). I am having problems meeting setup timing in TimeQuest right now.
