21584 Discussions
Can't access altera training
So I went to access the altera training site today and I cannot access any of the courses. Is this something that is expected to be resolved any time soon or is it a problem on my end?
Using Firefox on windows to view the Altera site and I am logged into myAltera.
Every class times out with the following or similar message:
failure of server apache bridge:
No backend server available for connection: timed out after 10 seconds or idempotent set to OFF.
build date/time: dec 5 2007 15:19:54 change number: 1014998
Apparently, Firefox doesn't work so I had to use IE. Also, the direct links from the cirriculum pages are broken... you have to go to the schedule page and select them from there register... then access them from your profile.
Which is quite strange seeing as them courses themselves are HTML5.
I have used firefox last week to get some on-line courses without any problems. Since than I have updated firefox, don't know if it works with that version. You couldntell Altera about this.
