20237 Discussions
Can't connect to JTAG on EP4CE6 Mini Board
PRolp
I'm trying to use this board but failing to connect to JTAG on it, either via the command line jtagconfig or via Quartus. https://www.ebay.com/itm/Altera-EP4CE6E22C8N-Mini-FPGA-Board-Cyclone-IV-/112023254939
The device appears correctly in lsusb:
Bus 001 Device 010: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
and in dmesg:
[795296.547927] usb 1-4: new full-speed USB device number 10 using xhci_hcd [795296.709676] usb 1-4: New USB device found, idVendor=0403, idProduct=6001 [795296.709685] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [795296.709691] usb 1-4: Product: FT232R USB UART [795296.709696] usb 1-4: Manufacturer: FTDI [795296.709701] usb 1-4: SerialNumber: AL0141DU [795296.712569] ftdi_sio 1-4:1.0: FTDI USB Serial Device converter detected [795296.712655] usb 1-4: Detected FT232RL [795296.712939] usb 1-4: FTDI USB Serial Device converter now attached to ttyUSB0
and I've tried various combinations of running jtagd as root, copying pgm_parts.txt files around, setting permission on /dev/ttyUSB0, basically everything I could find by googling. My suspicion is that the USB device appearing as an FTDI part instead of an Altera part is what's killing this even though the product ID 6001 matches the USB-Blaster ID, does anyone know more?
Some more output of various commands:
$ jtagd --foreground --debug JTAG daemon started Using config file /etc/jtagd/jtagd.conf$ jtagconfig No JTAG hardware available
ak6dn
Valued Contributor III
Product ID is dependent on Vendor ID. So even if the Product ID is the same, if the Vendor ID is not correct, it will not be detected.
On my Terasic FPGA board that implements an embedded USB Blaster, I see this:
Device Descriptor:
bcdUSB:            0x0110
bDeviceClass:        0x00
bDeviceSubClass:     0x00
bDeviceProtocol:     0x00
bMaxPacketSize0:     0x08 (8)
idVendor:          0x09FB (Altera)
idProduct:         0x6001
bcdDevice:         0x0400
iManufacturer:       0x01
iProduct:            0x02
iSerialNumber:       0x03
bNumConfigurations:  0x01
Same data for my standalone Terasic USB Blaster clone. So unless you can change to the correct Altera Vendor ID in the hardware (0x09FB) OR change your USB driver install files to look for your different VendorID (0x0403) your hardware will not be recognized.
Abe
The USB port is not meant for programming the FPGA. Its meant for USB to UART PC communications when developing NIOS-II based applications or any other applications that need PC serial communications.
The board uses the standard 9-pin JTAG programming interface. You need to use the standard Altera Byte-Blaster download cable to program this board/device via JTAG interface.
The website clearly states the following:
JTAG configuration interface
So you need to buy the Altera Byte-blaster JTAG download cable and use it. Only the later boards feature on-board USB-Blaster and use the USB Blaster cable.
