Hello ,
Thank you for your support earlier. We still have some outstanding questions that need to be addressed.
1- Regarding the following part "10M08SAE144I8G"; Would you please confirm if this part is fully RoHS 2 compliant, with or without exemption? If with exemption, can you provide the exemption code?
2- Regarding each of the following parts:
10M08SAE144I8G
10M16SLY180I8G 99AN0N
-- Could you please provide us with the current lifecycle status (e.g., Active, NRND, to be discontinued (LTB), obsolete, Custom) for each part?
3- Regarding each of the following parts:
10M50SAE144C8G
10M08SAE144C8G
10M08SAE144I8G
-- Please help us know if each part is affected by any of the SVHC materials listed in the latest REACH version (REACH 240 - published in Jan-2024) or not based on new article Definition (O5A) , and if so, kindly mention the SVHC material name affecting the part and its concentration.
4- Regarding each of the following parts:
10M08SAE144I8G
10M50SAE144C8G
10M08SAE144C8G
-- Please provide us with the TSCA compliance status .
5- Regarding each of the following parts:
10M08SAE144C8G
10M50SAE144C8G
-- Please provide us with the PFAS Status for each part number indicating if it is affected or not? if it is affected, please provide us with the Substance Name and CAS number.
Any further assistance you can provide would be greatly appreciated.
Thank you,
Mohamed Salem
Supplier Relations|Component Engineer
SiliconExpert Technologies
Mohamed Salem|European/International (T) : +1 617-865-5280
Jonathan Lacson|North America (T) : +1 669-244-3065
supplier.relations@siliconexpert.com
Good day
Sorry for the delay as I was out of office for a long period. Thank you for reaching out. I'm Nazrul Naim looking into your issue and allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
Sorry for the delay. I'm still in the midst of the discussion regarding this with the internal teams. Unfortunately, it takes longer than usual heard. I will plan on letting you know as soon as I learn more information. Really appreciate your patience.
Warm Regards,
Nazrul Naim
Below is the information need as requested.
1. For your information 10M08SAE144I8G is RoHs Compliant without exemptions.
2. Lifecycle status for 10M08SAE144I8G & 10M16SLY180I8G are Active
3. Attached dear customer letter (DCL) on REACH
4. TSCA : (https://cdrdv2.intel.com/v1/dl/getContent/680184?fileName=Intel+DCL+US+TSCA+PBT+restriction+July+2021.pdf)
5. 10M08SAE144C8G - https://cdrdv2.intel.com/v1/dl/getContent/695737?fileName=10M08SAE144C8G_20210324173446_v1.xml
10M50SAE144C8G - https://cdrdv2.intel.com/v1/dl/getContent/696772?fileName=10M50SAE144C8G_20210324173624_v1.xml
Hope that helps.
Nazrul Naim
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
