21458 Discussions
[Case:752259]Technical Data Inquiry for Volvo
MohamedSalem
Greetings,
SiliconExpert is contracted by Volvo to work with their suppliers for accuracy and compliance purposes.
We would appreciate your support to provide us with the Fabrication Site facilities, Wafer Test Site, Assembly Site facilities, and Final Test Site columns and identify the primary facility of Fabrication and Assembly for this part (LH8066803102501S REK7).
Volvo appreciates your support, and please inform us if this should be routed to a more appropriate contact and/or department.
FvM
the questioned part is an Intel microprocessor, not a FPGA, you are asking in wrong forum.
I also doubt that your customer wants to inform the public which components are used or planned for their designs.
Farabi
"We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
Thank you for your understanding."
