I am working on a DE1 starter kit. I want to use the CFI with SOPC. I have quartus II 6.1 and NIOS2 6.1. Here you can find my project with SOPC : http://img27.imageshack.us/img27/4353/sopc.th.png (http://img27.imageshack.us/my.php?image=sopc.png) Here you can find a part of my top level whit the links between the CFI and my SOPC. http://img413.imageshack.us/img413/6960/routage.th.png (http://img413.imageshack.us/my.php?image=routage.png) But I have a problem with NIOS2 when i try to run my program or when i try to flash my CFI, I have this kind of message:
Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: OK
Reading System ID at address 0x00405130: verified
Initializing CPU cache (if present)
OK
Downloading 00000000 ( 0%)
Downloaded 10KB in 0.1s
Verifying 00000000 ( 0%)
Verify failed between address 0x0 and 0x2787
Leaving target processor paused
I have read a lot of advice on this forum:- to check my reset address
- to check my execption address
Hello everybody,
somebody has an idea? Best regards jerome- Mark as New
In your QSYS (SOPC) tool you might have besides flash memory on-chip memory. In setting of the Nios2 set both vectors to that on-chip memory. Than build QSYS, compile design and program the FPGA. After that create a project in Eclipse. Than open Eclipse>NiosII>BSP_editor and open the bsp file stored in your project. In BSP editor click on the Linker script, than in Linker region name change value from flash memory to on-chip memory, generate and save.
I've fix this problem this way.
Topic Options
