Cfi S29al032d
I am working on a DE1 starter kit.
I want to use the CFI with SOPC. I have quartus II 6.1 and NIOS2 6.1.
Here you can find my project with SOPC :
http://img27.imageshack.us/img27/4353/sopc.th.png (http://img27.imageshack.us/my.php?image=sopc.png
Here you can find a part of my top level whit the links between the CFI and my SOPC.
http://img413.imageshack.us/img413/6960/routage.th.png (http://img413.imageshack.us/my.php?image=routage.png
But I have a problem with NIOS2 when i try to run my program or when i try to flash my CFI, I have this kind of message:
Using cable "USB-Blaster ", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x00405130: verified Initializing CPU cache (if present) OK Downloading 00000000 ( 0%) Downloaded 10KB in 0.1s Verifying 00000000 ( 0%) Verify failed between address 0x0 and 0x2787 Leaving target processor paused I have read a lot of advice on this forum:
  • to check my reset address
  • to check my execption address
http://img54.imageshack.us/img54/5459/exeption.th.png (http://img54.imageshack.us/my.php?image=exeption.png
but now i have no idea.
I don't understand.
On my design the reset is on the vcc, is it correct?
i set the setup and hold time of the CFI at 70ns. Is-it correct?
Please help me :(
Jerome
Hello everybody,
somebody has an idea?
Best regards
jerome
In your QSYS (SOPC) tool you might have besides flash memory on-chip memory. In setting of the Nios2 set both vectors to that on-chip memory. Than build QSYS, compile design and program the FPGA. After that create a project in Eclipse. Than open Eclipse>NiosII>BSP_editor and open the bsp file stored in your project. In BSP editor click on the Linker script, than in Linker region name change value from flash memory to on-chip memory, generate and save.
I've fix this problem this way.
