21417 Discussions
Change VHDL generic via command line for synthesis
anonimcs
New Contributor III
Hello everyone,
I have a project which consists of multiple IPs. I have a qsys file for each configuration of the IPs and I also have a top-level generic that allows me to not have a duplicate of VHDL code just for having different input bit widths. My question here is that I want to configure the generic via command line (or with some scripts) but I couldn't find a way to do so. The closest thing I could find is creating project revisions, but those are not fully flexible as we need to create all project-related files before running synthesis. I was wondering if anyone could configure their generics via command line without having to copy all the project files + the vhdl source code
ShengN_Intel
then how should I make the pin assignments for the pins not used when generic = 0 (they're only used when generic = 1). Is there a way to set them 'conditionally' in the qsf file ?
For above mentioned can't be achieved in .qsf, you may need to use .tcl script if/then/else already as mentioned. For example like below in .tcl:
set a [get_parameter -name C3_CNT]
if {$a == 1} {
    set disable 0
    set enable 1
} else {
  set enable 0
  set disable 1
if {$enable} {
set_location_assignment PIN_W28 -to outclk6 -disable -comment IOBANK_3C -remove
set_location_assignment PIN_W28 -to outclk6 -comment IOBANK_3C
export_assignments
if {$disable} {
export_assignments
Remember that if want to enable, make sure source the .tcl twice in order to remove the previous -disable assignment.
[Take Note This]: Critical Warning(19941): QSF command 'set_parameter' can only apply to the top-level design and cannot include '-to' or '-entity' arguments.
If you notice that 'set_parameter' doesn't take effect, remove the '-to' or '-entity' arguments because it can only apply to top-level design.
Sheng
ShengN_Intel
Hi
May use this set_parameter Tcl command https://www.intel.com/content/www/us/en/docs/programmable/683432/22-4/tcl_pkg_project_ui_ver_1-0_cmd_set_parameter.html on your top-level generic.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
anonimcs
New Contributor III
Looks promising, which file should I add this command to ?
Cheers,
ShengN_Intel
You can add this tcl command to a .tcl file. Then go to View -> Tcl Console, in the Tcl Console type source <file_name>.tcl. Besides, can go to Tools -> Tcl Scripts and then Select and Run.
Also, you can straightaway include that tcl command in the .qsf file.
Sheng
anonimcs
New Contributor III
Adding the tcl command directly to the qsf file is totally fine for me, but I have a follow-up question. As I mentioned, the entity's port widths are dependent on this generic, then how should I make the pin assignments for the pins not used when generic = 0 (they're only used when generic = 1). Is there a way to set them 'conditionally' in the qsf file ?
Cheers
ShengN_Intel
Sorry for confusion. The package require ::quartus::project is not needed in the previous post community.intel.com/t5/Programmable-Devices/Change-VHDL-generic-via-command-line-for-synthesis/m-p/1534942#M93067 situation. It'll only be needed when you want to project_open and export_assignments the tcl assignment like the .tcl script attached below. Btw, you can generate the .tcl script attached below by going to Project -> Generate Tcl File for Project.
Forgot to mention that if you want to source the .tcl script in command prompt you can use this command quartus_sh -t
sheng
sstrell
It's just Tcl scripting, so you can use if/then/else.  Good Tcl reference:
https://tmml.sourceforge.net/doc/tcl/index.html
ShengN_Intel
if {$a == 1} {
    set disable 0
    set enable 1
} else {
  set enable 0
  set disable 1
if {$enable} {
export_assignments
if {$disable} {
export_assignments
Sheng
