21611 Discussions
Changing the USERCODE value
I have a few chips (MAX3000A) and one compiled pof-firmware.
I want a write this POF-file in each chip with different USERCODE (in my case usercode will be treat as device ID).
How can I change USERCODE value im POF-file WITHOUT recompiling project?
USERCODE can be modified in the device settings menu, under devices. Since the usercode is a dedicated register, you won't need a full recompile. Just run the assembler stage. Processing -> Start -> Start Assembler.
