21602 Discussions
Chip INTEL MAX 10
Noragami
Hi , Everyone
           I'm building a custom-built FPGA board and purchasing a FPGA chip ( 10M08SAE144C8G ) to solder it on. And now I started the configuration program into FPGA by JTAG ( USB Blaster ) , but it shows an error message " Unable to scan device chain. Can't scan JTAG chain. Do you want to open the JTAG chain Debugger to troubleshoot the JTAG chain ? ". When i'm to open JTAG chain Debugger and click Test JTAG Chain  then show error message "JTAG chain problem detected " and " No device detected
          The prototype I used to design the board was the MAX 10 FPGA Evaluation Board, which I personally designed. When trying the configuration program, the device does not show up like a prototype board. I wonder if Maybe there is a setting inside the chip to enable or not. If there is any way to enable the chip for me please.
Thank you.
NurAiman_M_Intel
Thank you for contacting Intel community.
Kindly refer to solution in the case link below as it has the same error as yours.
Let me know if you need further information.
https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/Unable-to-scan-device-chain-Cant-scan-JTAG-chain-EMERGENCY-HELP/td-p/265605
Aiman
