21605 Discussions
Clock data recovery
Hey, i am quite new to fpga stuff but in my current project i need to decode a 40MHz Manchester encoded signal. As far as I understood there are different ways to do this but one is to use a pll to recover the clock from the input stream.
Is this correct and if so can someone tell me how to configure the pll? (So far I only used the megafunctions to create a pll with static frequency)
I was already looking for some application notes but didn't find too much Information.
The transceivers available in various FPGA families can be configured to perform Clock and Data Recovery (CDR) from a received serial stream. However, I suspect the data rate you're looking at may be too low. For reference look at the "Transceivers" section of the "cyclone v device handbook (https://www.altera.com/en_us/pdfs/literature/hb/cyclone-v/cv_5v3.pdf)".
However, at 40MHz (is that 40Mbps with transitions at 80MHz?) you could consider 'simply' over-sampling the received data with a fixed local clock, possibly generated from a PLL in the manner you're familiar with.
Cheers,
Alex
I would over-sample as well, unless you need to recover the clock from some reason other than decoding the data. Alex - 40Mbps Manchester = 40MHz, not 80MHz.
Just for clarity - A 40Mbps Manchester encoded stream potentially has transitions every 12.5ns. Thus you will need to oversample what is effectively an 80Mbps signal.
Cheers,
Alex
