Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Communication between PC and FPGA kit with ethernet phy chip
I need to read data off of a Stratix IV GT via the on board Ethernet port. That is, from a s4gt to a Marvel 88E1111, then to the PC. One direction, reasonable rate (Mbps).
I have some working knowledge in VHDL and Labview.
My questions are, can I simply program the hardware? do I have to implement NIOS processor and TSE megafunction? Does Marvel offer a Labview driver or library?
Thanks very much,
ak
Highlighted
Re: Communication between PC and FPGA kit with ethernet phy chip
The easiest way is to use a Nios-II processor with the TSE IP block.
