I'm trying to build uClinux using the code from alterawiki but I get this compilation error
serve_image.c: In function ‘main’:
serve_image.c:32: error: storage size of ‘hints’ isn’t known
serve_image.c:94: error: ‘AI_ADDRCONFIG’ undeclared (first use in this function)
serve_image.c:94: error: (Each undeclared identifier is reported only once
serve_image.c:94: error: for each function it appears in.)
serve_image.c:97: warning: implicit declaration of function ‘getaddrinfo’
serve_image.c:99: warning: implicit declaration of function ‘gai_strerror’
serve_image.c:99: warning: format ‘%s’ expects type ‘char *’, but argument 3 has type ‘int’
serve_image.c:103: error: dereferencing pointer to incomplete type
serve_image.c:104: error: dereferencing pointer to incomplete type
serve_image.c:105: error: dereferencing pointer to incomplete type
serve_image.c:110: error: dereferencing pointer to incomplete type
serve_image.c:32: warning: unused variable ‘hints’
make: *** Error 1
make: Leaving directory `/home/developer/altera/nios2-linux-bak2/uClinux-dist/user/mtd-utils/36d8de81049c9c908740b690c664b5bd3703ccd6'
make: *** Error 2
make: Leaving directory `/home/developer/altera/nios2-linux-bak2/uClinux-dist/user/mtd-utils'
make: *** Error 2
make: Leaving directory `/home/developer/altera/nios2-linux-bak2/uClinux-dist/user'
make: *** Error 2
make: *** Error 1
Can you help me?
--- Quote Start --- I'm trying to build uClinux using the code from alterawiki but I get this compilation error
make: *** Error 1
make: *** Error 2
make: *** Error 2
make: *** Error 2
make: *** Error 1
Can you help me? --- Quote End --- It worked when I stopped mixing the mmu toolchain with the mmu-ess toolchain. I could eventually run my project with the DE2-115 board.
Topic Options
