21602 Discussions
Configuration file size
hey,
what should be a typical size of a configuration file (I means to the size it use in the flash, in order to decide what flash size should I use and if I can put more than one configuration file in it..)?
Is it depends on the specific device? Or in how many of the device resources were used?
Is it making any scene that a cofiguration files use about 17 mega bytes of the flash?
Thanks ahead!
It does depend on the device. You will have to check in the datasheet to see how large the configuration file will be. The configuration file size does not change with utilization.
/Boris
Configuration file of the largest Arria-10 chip is 42.8MBytes.
The data is in Table 78 on page 83 in a10_datasheet.pdf
Evgeni
Thanks for the sharing in this post. I never aware that the configuration file size info is available in the datasheet.
Just FYI, for V series onwards, the file size are documented in datasheet.for older device they are in configuration chapter.
Anyone happens to know how huge can JAM file size go for MAX V?
this information is help full. thanks a lot.
