21602 Discussions
Configure fpga with jam STAPL failure-more question
mxy_bw
I posted a question last time and got a response but I can not post reply at that thread. The "Post Reply" button is not clickable all the time. So I post a new one The original thread named by:  Configure fpga with jam STAPL failure
The quaruts version I use is quartus prime 18.0.
How to use the JAM player command to disable the real-time ISP feature. Is that like "jam -aconfigure -ddo_real_time_isp=0 .jam"? I excute above command but still configure failed. Please check attachment.
I checked  document AN-425, Cyclone device family only support "configure" action and "do_read_usercode" "do_halt_on_chip_cc" "do_ignore_idcode_error" options, not mention to " do_real_time_isp".  So can we still excute jam player with -d optional to disable the real-time ISP feature?
And anothe question is about jam file. I ues a jam file convert from sof file. Because I can't convert from pof to jam with Cyclone device. Is this because Cyclone device not support "program" action?
Fakhrul
Hi mxy_bw,
Normally, you should be able to generate the jam file from pof. Can you share how did you manage to generate the file? I saw your post here, check this : https://community.intel.com/t5/Intel-Quartus-Prime-Software/How-to-generate-JAM-file-from-pof/td-p/1575331
Fakhrul
Fakhrul
As we do not receive any response from you to the previous notification that we provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
