Programmable Devices
21399 Discussions
Connection between two inout ports
IonHide
Hello, I need to connect the 10 inout pins(A) to 10 inout pins (B) based on the logic of the cntrl signal (C) with respect to clock.
i-e when C = 0 , connect port A to port B &
      when C= 1 , connect port B to port A.
what is the syntax I could follow to acheive the same , while simulating It not showing the results as needed.
Regards.
Farabi
Do you have the verilog code? we can try to take look at it.
regards,
Farabi
IonHide
always @(posedge clk) begin
 if (C) begin
  B_out = A;
  A_en = 0;
  B_en = 1;
 end else begin
  A_out = B;
  A_en = 1;
 B_en = 0;
 end
end
assign A = A_en ? A_out : 10'bz;
assign B = B_en ? B_out : 10'bz;
where A, B are inout ports , C input signal& others are local registers.
Regards.
FvM
doesn't look bad. Don't know which problem you experience. First output after direction signal change will be invalid due to registered x_en signal. E.g. C 1->0, A_ out latches old B output, then deactivate B and enables A. Unregistered x_en may achieve intended behaviour.
If you don't get reasonable output at all, it's probably due to testbench design fault.
NazrulNaim_Intel
Sorry for the delay. Regarding your issue, have you tried this coding before?
// Declare registers for A, B, and control signals
reg [9:0] A_out, B_out;
reg A_en, B_en;
reg [9:0] A, B;
  if (C) begin
    // When C is high, transfer A to B
    B_out <= A; // Use non-blocking assignment
    A_en <= 0;
    B_en <= 1;
  end else begin
    // When C is low, transfer B to A
    A_out <= B; // Use non-blocking assignment
    A_en <= 1;
    B_en <= 0;
  end
end
// Drive A and B based on enable signals
always @* begin
  if (A_en) begin
    A = A_out;
  end else begin
    A = 10'bz; // High impedance when not enabled
  end
  if (B_en) begin
    B = B_out;
  end else begin
    B = 10'bz; // High impedance when not enabled
  end
end
Hope that helps and do let me know if I can assist you further.
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
