21416 Discussions
Cpld epm7256 burning
LFu001
Hi all, I need to burn cpld epm7256 and while using byteblaster usb and quartus 13 i can't access the device as it seems on the attached files, what does i miss?
Thank you.
YuanLi_S_Intel
Hi Liran,
Instead of selecting "Examine", can you please select "Program/Configure" for programming?
YL
LFun0
This card is working and i am affraid to erase the program that is already loaded to the epm7256,
Examine shall not work? ​
YuanLi_S_Intel
Hi Liran Fun,
Examine is not meant for programming / burning. If thats the case, i would suggest you to burn SOF file into the device as it is volatile.
YL
ak6dn
Valued Contributor III
This is a CPLD device, which is EEPROM based, not SRAM based. It uses a .pof file for programming, NOT a .sof file.
The option you could try is a VERIFY of the programmed device versus a known .pof file, if you have one.
The only other option is to reprogram the CPLD with a .pof file and do a verify after programming to validate it programmed correctly.
There is no way to download a new temporary file to try it without completely reprogramming the device.
