21615 Discussions
Creating IP from the IP catalog
pgigliotti
I have navigated to the IP catalog in my Quartus 21.1 design. I am trying to generate a clock module that brings in a 50 Mhz clock and generates two outputs one at 80 Mhz and the other at 150 Mhz. I select the "PLL Intel FPGA IP" from the catalog box, and give the component a name, select VHDL as the type and hit save, and nothing happens! the dialog box closes, but no additional dialog opens and no files are created?
sstrell
Did you generate the IP?  You don't mention Standard or Pro, but in the IP Parameter Editor, you have to generate the IP to create the files.
ShengN_Intel
Any further update or concern?
ShengN_Intel
After clicking ok, have to wait for a while for the Megawizard window to pop out like this pic:
If still there's problem for Megawizard window to pop out, try to re-installed the Quartus Tool and see.
Sheng
ShengN_Intel
Sheng
pgigliotti
I reinstalled the Quartus tools, and the issue has been resolved.
