Programmable Devices
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
18483 Discussions
Cyclone 10 GX 3V IO Voltage
JLee25
Hi community,
I have a new project based on C10 GX and I am debugging the IO problem.
The device is 10GX220YF672, the IO bank 2L was design to interface 3V IO.
I download a counter design to verify the operation, it will toggle every 200 ms.
From waveform, the high level is only 0.9V instead of 3V that I am expected.
What would be the problem?
If my external devices boot earlier than FPGA, will it cause this issue?
Please help!
BRs,
Johnson
YuanLi_S_Intel
Hi Johnson Lee,
Just want to check, have you set the IO Standard of Bank 2L to 3.0V?
It is not a problem for an external devices that boot earlier than FPGA if you obey the pin state as shown in the user guide:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10gx-51003.p... (Page 273).
For example, LVDS I/O banks need to be tristated (Setting in Quartus) while power up and vice versa.
Thank You.
JLee25
Hi YL,
Thank you for reply.
Yes, I did set the IO standard to 3.0V.
Attached is the qar file for your reference.
I test 2 boards with this configuration.
Both show the same status,
before config, gpio_0 is 3V, led_0 is 0.7V. After config, gpio_0 switch between 3V/ 0 V. led_0 is 0.9V/ 0V.
Johnson
JLee25
Hi YT,
I just found the clock was not operated properly, amplitude is small..
I will check it and see if this is the root cause!
Thank you!
Johnson
JLee25
Hi YT,
I have a question on the reference file.
From the table below, it means the external IO pin should be in Tristate during FPGA boot up ?
If above rule can’t be followed, what will happen to the device?
And what should I do to prevent this?
Boot external devices later than FPGA ?
Please comment.
Thank you!
Johnson Lee
YuanLi_S_Intel
Hi Johnson Lee,
No tri-stated is needed from external pin. During FPGA power up, the pin itself will tri-state for used pin. Meanwhile for unused pin, you will need to do some setting in Quartus to enable tri-stating.
To do so, go to "Assignments" -> "Device" -> "Device and pin info" -> "Unused pin" -> "As input tri-stated with weak pull up"
Thank You
