21607 Discussions
Cyclone 10 GX EMIF PLL clock input
After compiling a EMIF for Cyclone 10 GX, I noticed that it insists on using an external differential clock. Attempts at routing internal PLL output to pll_ref_clk input results in error. Does that mean I have to use an external LVDS oscillator, or loop a differential PLL output back to this?
--- Quote Start ---
--- Quote End ---
• This is user configurable option in C10 EMIF IP under PLL refclk section.
• Set in EMIF IP thenuse the IO standard that being set in EMIF IP.
--- Quote Start ---
--- Quote End ---
• Yes, this is expected. C10 EMIF PLL refclk need to come externally from board.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
FHint
New Contributor II
is this also applicable for Arria 10devices?
I have found a source that states that in Quartus II 14.1 and earlier, this was also not possible for Arria 10 FPGA, but I have the same problem with Quartus 17.1.
Why is it not possible to generate the EMIF ref clk with a PLL? The *_readme.txt file says, that the ref clk is optional.
Best regards
