21588 Discussions
Cyclone 10 GX LVDS input voltage tolerance
JB_ISDI
What is the absolute maximum pin voltage, and differential voltage, for an LVDS input with 1.8V VCCIO?
Referring to the datasheet C10GX51002 2018.06.15, Table 13 says recommended max Vi = 2.19V, but is this the absolute maximum? Table 3 implies that an LVDS I/O pin can survive 2.50V for 50% of lifetime, but this is based on a pulse signal. Table 1 gives absolute maximum DC current for IO pin = +/- 25mA.
In my application, an external IC can drive up to 2.4V with max current 19mA, for about 1s, before LVDS levels are established. Will this destroy the LVDS input on the Cyclone 10?
ShafiqY_Intel
Hi JB_ISDI,
The LVDS I/O pins can tolerate a maximum of 10 mA per pin and a total of 100 mA per I/O bank.
The voltage level of the LVDS I/O pin must not exceed 1.89 V.
You may refer to following document for more details:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an692.pdf
Matt
