21235 Discussions
Cyclone 10 GX LVDS termination, can it do OCT?
Oliver_I_Sedlacek
New Contributor III
The Cyclone 10 GX development kit includes an FMC connector with loads of LVDS lanes, so the LVDS receivers need termination, right? I don't see terminators on the schematic and I don't see that the Cyclone 10 GX can do OCT (on chip termination) for LVDS. I sure can't find this as an option in Quartus Pro! Does this mean there's no way to do the termination on the development board.
FvM
Differential termination can be also enabled in Pin Planner. The respective column must be switched on in context menu first.
AqidAyman_Intel
Cyclone 10 GX does support On-Chip I/O Termination which you can refer Table 43 from below link on the OCT schemes supported for LVDS I/O.
https://www.intel.com/content/www/us/en/docs/programmable/683775/current/on-chip-i-o-termination-in-devices.html
Furthermore, Figure 78 shows the termination for differential receiver. It also mentioned that you can enable on-chip termination in the Assignment Editor inside Quartus Prime Pro software. For more details, you can refer below link:
https://www.intel.com/content/www/us/en/docs/programmable/683775/current/differential-input-rd-oct.html
FvM
Oliver_I_Sedlacek
New Contributor III
Thanks to both of you. It makes sense, I just didn't stumble across anything when searching through the help.
AqidAyman_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
