21615 Discussions
Cyclone 10 LP FPGA
MK_ABQ
New Contributor III
I would like to know the following two things about Cyclone 10 LP - 10CL040YF484C8G
1) Which quartus versions support this FPGA?
2) What is the core fabric speed of this FPGA ( Speed grade 8 is slowest as per part number),
but I would like to know the speed in Hz.
Datasheets/user guide doesn't seem to mention it. Can you help?
FvM
you find Cyclone 10 LP maximum core clock speed in datasheet, C8 402 MHz, I8 362 MHz
The device is supported by all recent Quartus std or lite versions, I believe starting with V17.0.
wuyuetian
Regarding the issue of 10CL040YF484C8G $100 discontinued replacement large quantity ordering, we have set up a special team to conduct research and achieved good results. Are you interested in joining?
Email: jack@aceicc.com
FvM
NurAiman_M_Intel
FVM answer is verified. Hope you can now proceed with your design. It is recommended to use the latest Quartus version for new design.
Aiman
