21611 Discussions
Cyclone 10GX Differential termination
dkurgs
Greetings all,
we are designing a PCB including the Cyclone 10GX220 and were slightly confused by the datasheet.
We wish to terminate an incoming LVDS pair using the normal 100 Ohm differential termination (the datasheet calls it RD).
Do we still need to calibrate the OCT? Should we still connect an external OCT calibration resistor to the bank's RZQ pin?
Thanks!
EngWei_O_Intel
Hi Daniels
Thanks for your inquiry.
If you have the OCT enabled for the FPGA, you do not need external termination. There is no calibration needed for Rd OCT.
Eng Wei
EngWei_O_Intel
Hi Daniels
Eng Wei
EngWei_O_Intel
Hi Daniel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
