Cyclone V is a Field Programmable Gate Array (FPGA), meaning it can be programmed and reprogrammed out in the "field" to any logic configuration desired:
https://www.intel.com/content/www/us/en/products/details/fpga/cyclone/v.html
Hi Divjot,
Yes, it is correct as explained by sstrell. In addition, low cost FPGA systems have different needs, depending on the application. However, two common themes are the need for high functionality, coupled with the lowest possible power. In some applications, like portable handheld equipment, battery life drives power concerns. In others, like wireless communications, thermal budgets, constrained by high reliability fan-free operation require low power.
To address these needs, Intel developed Cyclone V FPGAs.
We do not receive any response from you to the previous question/reply/answer that have been provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
