21611 Discussions
Cyclone IV Decoupling
Hi All.
I have a Cyclon 4 FPGA (EP4CE22) and need to know the capacitors to use for decoupling.
I found and schematic example in Altera web page but is for Cyclon 4 GX and I am not sure it work in the same way.
Also I fount the Power Delivery Network Design Excel, that Altera gives you to find the capacitors to use, but I really didnt undesrand.
I am going to use a 40Mhz clock, and the power consumption is going to be this:
Iccint = 0.9A
Icca = 0.04 A
Iccd = 0.008 A
Iccio = 0.04 A
the most important I thing is the Iccint, so if anybody can help me to know how to do the decoupling it will be great.
Thank you very much.
What package? Altera does a pretty good job at supplying app notes for decoupling. Have you looked around on the website?
You are not running very fast at 40MHz. Are you planning on using any PLL's? On the BGA packages the VCCINT pins are typically all located in the center of the chip. Use 0402 package ceramic capacitors, something like a 0.01uF and 0.001uF (1000pf) pair for every couple of VCCINT pins or whatever you can reasonably pack in underneath the center of the FPGA should suffice for your needs.
Throw a couple of 20uF bulk Tantalum caps outside near the perimeters of chip.
Rob
Thank you very much Rob.
It was very helpful.
Best regards
Iair
