20403 Discussions
Cyclone IV E: EP4CE22F17C8 I/O pins misbehaving
AWrithingMassOfFlesh
Hi All,
I am developing with the Cyclone IV E: EP4CE22F17C8. I am observing anomalous behavior from two of the I/O pins on the chip.
I have pin A11 configured as a general purpose output, however when I try to drive a signal to the pin, the output remains high. I have other pins tied to the same signal as A11, but those pins do output the signal as expected.
Pin L14 is configured as MISO for a SPI bus. The problem is that this pin is being held high for some reason. I configure this pin identically to the other MISO pins in the design and those busses are working as expected.
Is this a known issue with the chip? I have tried different configuration settings on these problematic pins, however the behavior does not change. I also have examined x-ray images of the PCB and there appear to be no flaws in the mounting of the chip.
Any insight into debugging this issue would be greatly appreciated.
Thanks!
I found the issue. I was assigning the wrong pins. I was supposed to be driving A12 instead of A11 and L13 instead of L14.
sstrell
Can you show your design and any assignments you've made to these pins (pull-ups, etc.)?
These are the pin assignments below. I circled the problematic pins, and also show the pins that are working correctly with the same configurations. The fact that I am applying the same assignments to these pins and getting different behavior it what I don't understand. I also use the same logic and assignments in a separate project for a different Cyclone IV device where it works as expected.
ak6dn
Valued Contributor III
Are you doing this on a development board, or your own custom PCB design?
I have a TerAsic DE0-NANO development board which uses that same part (just a different speed grade) and I use those same I/Os as 3.3V LVTTL no problem.
sstrell
It would be helpful to see code to understand how you are driving the output and how you are receiving the input.
This is using a custom PCB.
For testing purposes, I drive pins A11 and A13 with a 1MHz clock signal generated by the Quartus PLL IP block. Using an oscilloscope I probe the pins, and I can see the 1MHz waveform output from A13, however, the output form A11 is a constant high signal.
Pin L15 is the MISO to a peripheral ADC. For Pin L14 I use logic and assignments which have worked on a previous device. Moreover I have an identical interface elsewhere in this project which behaves as expected. Using the oscilloscope I can see that Pin M7 is able to be controlled by the peripheral chip. Pin L14 should behave the same but is being held high the entire time.
module ad7276(
input clk, //PLL clock 48MHz
input rstn, //PLL Lock signal
input shdn_ext, //Hardware wire OR'd laser shutdown
output reg SCK, //ADC SCK 24MHz
output reg SCSn, //ADC CS
input MISO, //ADC Master-IN Slave-OUT
output reg [11:0] MEAS, // Measurement
output reg meas_rdy
reg [5:0] count; // [0-13] Tconv, [14] Tacq, (b0 & b13 read 0)//0-26 Tconv, 27-28 Tacq
reg [11:0]dummy_meas;
reg SCSn_d;
always @(posedge clk)
begin
if(!rstn || (count == 38))
count <= 0;
else
count <= count + 1'b1;
end
begin
if(!rstn)
begin
SCK <= 0;
SCSn <= 1;
end
else if((count <= 2) || (count >= 37))
begin
SCK <= 1;
SCSn <= SCSn_d;
end
else
begin
SCSn <= SCSn_d;
SCK <= !SCK;
end
end
//CS low except during acquisition (2 clock cycles @ 48MHz)
begin
if(count == 38)
SCSn_d <= 0;
else if(count >= 38) //was 35. wasn't getting above 1.5V on o-scope TP
meas_rdy <= 0;
else if(count >= 34)
begin
SCSn_d <= 1;
MEAS <= dummy_meas[11:0];
meas_rdy <= 1;
end
else
begin
SCSn_d <= 0;
meas_rdy <= 0;
end
end
//Clock data_in with SCK when count = 6-28 and CS is low //deserialize miso
always @(posedge SCK)
begin
if(count >= 6 && count <= 28 && !SCSn)
begin
dummy_meas[13-((count/2)-1)] <= MISO;
end
end
endmodule
Also I generated these boundary scan files, although I am not entirely sure how to interpret them.
ak6dn
Ok, you say you are using a custom PCB of your own design. Is there just one instance you have built, or do other board(s) exhibit the same problem?
I am seeing the problem on multiple boards with the same design from the same batch. We have x-rayed the PCB's and seen that the FPGAs are mounted properly. At this point, we suspect the issue is either with the chips themselves or with the synthesis.
pre-config                                                        post-config
Can someone explain what these lines mean in the boundary scan files I uploaded? It looks like Pin L14 is present in the pre-configuration file but absent from the post-configuration file. I want to rule out the possibility that I am using the wrong configuration in Quartus. I'm using Quartus v20.1.1
