20405 Discussions
Cyclone IV E EP5CE55F23C8N Reference schematic design
Weidong
Hi
My design need use EP4CE55F23C8N chip, but I can't find an reference hardware design of it.
So,
It's a little difficult to start this hardware design, this chip have so many Pins...
I found some supporting documentation, but, if I can get an reference design, it is very helpful.
Such as: an schematic other people used.
My main concern is the use of pins, by referring to other people's pin assignments and combining my own design, I can easily confirm that my design is correct.
Do we have such files.
And,
It is difficult for me to find a local agent to get intel FPGA support in China. There is no direct person to connect with. So, I have to come here ask for help. Does Intel have this consideration.
Please provide some help, which will be very helpful.
Thank you.
EngWei_O_Intel
Hi there
We don't categorize the design into specific package ordering. You can search for example design for Cyclone IV below:
https://fpgacloud.intel.com/devstore/platform/?acds_version=any&family=cyclone-iv
For pin assignment, there are 2 main references you can check:
1. Pinout file (you can check the IO function per pin):
https://www.intel.com/content/www/us/en/programmable/support/literature/lit-dp.html
2. Pin Connection Guideline (you can check on description of each IO function)
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-iv/pcg-01008.pdf
Let me know if you have any question.
Eng Wei
EngWei_O_Intel
Hi there
Eng Wei
